That should be plenty. I believe you can use 3/8 (-6) up to around 700 hp
Just be sure to use a good regulator set at whatever carb you're running max bowl inlet.I am upgrading the motor in my 71 Nova to a 580ish HP SB 427. The builder has a mechanical 6 vane high volume fuel pump with -8an line going to carb that i am probably going to get with the motor. I have the stock tank with -6 fuel lines going to the carb now, would that be enough to support this engine? Not planning on racing the car.
Fuel tank vent should be minimum 3/8" I.D. Stock fuel tank vent is 1/4" I.D.I am upgrading the motor in my 71 Nova to a 580ish HP SB 427. The builder has a mechanical 6 vane high volume fuel pump with -8an line going to carb that i am probably going to get with the motor. I have the stock tank with -6 fuel lines going to the carb now, would that be enough to support this engine? Not planning on racing the car.
Yes no problem. Ernie.I am upgrading the motor in my 71 Nova to a 580ish HP SB 427. The builder has a mechanical 6 vane high volume fuel pump with -8an line going to carb that i am probably going to get with the motor. I have the stock tank with -6 fuel lines going to the carb now, would that be enough to support this engine? Not planning on racing the car.
