So I finally got the ole 355 going again after the cam decided to wipe a couple lobes off and take everything else out in its path. Its all broke in and I've been driving it here and there but now I'm having a problem when I brake hard it almost wants to stall. If I rev it in neutral or park and let off it also wants to stall. Then if I give it a little gas it studders a bit then clears right back out. Driving it around it runs pefect. Is it the fuel sloshing around in the bowls or something? Its got a 750 Double Pumper with a Proform center section, Holley Electric Blue fuel pump with regulator set at 7psi. The Tank is full of 110 Cam2 so I know its not running dry when I hit the brakes. Any Ideas?
