1 - 9 of 9 Posts
I have the 350 crate motor, and new fuel line 3/8, new fuel tank w/ a new sending unit. i installed a holley blue electric fuel pump and it failed so I replaced it w/ a mechanical. thing is with both pumps the fuel pressure guage falls to zero when the engine heats up. When the motor is first fired up its at 7 lbs pressure. ??????????/ Im lost........ this is the second guage by the way. Whats going on? plenty of fuel in the fuelbowl and can see it pumping with the site plug out.:eek:
If your guage is Liquid filled drain it or pull up the corner of the rubber stopper and vent it,
I just drained mine and it works fine
Nope, accually works better now, needle sits still.
I tried 2 differant guages and same thing.
You also might take a look and see if you fuel lines are heating up too, I had to wrap my lines in a cool-it sleve, down by the header.
Discussion Starter · #7 ·
Yeah, I wraped my fuel lines too. I did what you said and its staying at 5.5 and 6lbs now. Thanks and Ill keep an eye on it.:)
-rick
Discussion Starter · #9 ·
Yeah, thats what I was thinking. Thats when I pulled the site plugs from the bowls to look at the levels.
1 - 9 of 9 Posts
