I am about near complete with all wiring and lights except for my fuel gauge. On the back of the gauge are the two screw terminals that accept the circuit board. Then there is also a lead on the center of the gauge. Does this get wired to anything?
Currently, sender is new, good ground, and getting continuity throughout the circuit. Gauge never budged, sitting on "full". Suggestions appreciated. Thanks.
I'm guessing it is a factory gauge in that you said that accept the circuit board (as in flexible circuit board) ?.
This is off of memory as I cannot get to my gauges but there should be two connections off of the flexible circuit board to the back of the gauge. I'm thinking these connections are at the 3:00 and 9:00 position. One of these connections if you trace it through the flexible circuit board to where the main harness plugs into the instrument panel it will go just to one pin in this plug. The other connection in the flexible circuit board will also go to a different single pin in the instrument panels main harness plug but also will go another direction in the flexible circuit board to power up other things. This connection with it branching off would be powered with an ignition powered 12 volts while the other unbranched one would go to the tan wire in the loom which then goes back to the fuel tanks sending unit.
On vehicles that have a factory indash tach they use the same flexible circuit board but in the wiring harness instead of the sending unit wire from the fuel gauge going to the sender the wiring harness is different and the wire in the harness goes to the negative terminal on the ignition coil.
Since the flexible circuit board becomes more fragile as it ages there may be a hairline crack in it keeping the fuel gauge from getting power. If things are not all the way wired and the instrument panel is not grounded this too could keep the fuel gauge from working. Since the fuel gauge and tach are grounded through their mounting bolts and rely on the instrument panel having a ground going to it from behind the dash, this too could be your problem.
For testing you need to know which terminal connection on the fuel gauge should be getting an ignition 12 volts. Let's call this terminal connection "A". By grounding a test light or meter to a metal spot behind the dash, turn the ignition switch to the run position and see if the test light comes on or the meter reads about 12 volts on when the test light or meters other lead touches this spot (spot "A"). If it does, then you are getting power to the gauge. Now you need to check for ground. Take the test light and connect it to a source of power. It can be a battery 12 volts or ignition 12 volts. It doesn't matter. Now take the test lights other end and touch it to the housing of the fuel gauge and it should light up verifying the gauge is grounded.
Now all that is left is to see if the gauges needle can be made to move. Normally if nothing is connected to the sending unit terminal connection and the gauge has power and ground then the needle should swing to full or above. Let's say it's already above full and you can't see it move. The problem may be in the gauge so another test needs to be done. By grounding the sending unit terminal connection on the gauge the needle should swing down to empty or below. You still need to have power and ground being applied to the gauge or this test will not work.
Now if the grounded sending unit terminal connection on the gauge is ungrounded the needle should swing to full or above.
If the gauge is working as above then the problem is from the sending unit terminal connection rearward to and through the sending unit. If the gauges needle does not move or move fully to empty or full then the gauge has a problem. I'm not saying there could not also be a gauge and sending unit problem but further testing will reveal other things either working or not.
When finding out what terminal on the gauge should be for the sending unit and which should have power, double check and make sure you are right. I've hurried more than once and gotten things backwards and things can be damaged if not tested correctly.
