1 - 20 of 20 Posts
This may be a dumb question, I did some searching but couldn't find much for the 4th gen. I am looking to buy some wheels and tires for road racing.
What is the widest 15" that will fit in the front without rubbing? I have heard 15x8 may fit depending on the tire. Does anyone have any photos?
I am currently eyeing these wheels:
http://www.bassettwheel.com/dhole_asphalt.html
15x8 will fit, get wheels with at least 4" of back spacing. Tire size will have to be determined by your taste. I know 245/60's fit easily. The front track on the 4th gens is 1 inch wider per side then the rear track. For that reason I am running 15x7 on the rear and 15x6 on the front both with 4" of back spacing and it makes the track width even. Tubular control arms that are 1 inch narrower are available and will allow for larger tires and wheels to be used and still keep them under the fenders.
I believe its because the non-dot wheels are lighter?
It is my understanding that a 15x8 with 4.5" backspace fits well in the rear. Should this fit ok in the front as well? I can see how it would be handy to have four wheels that are alike.
A 15x8 with 4.5 bs will fit using a 225/60 tire, my friend has this setup on his 73' and clears, if the front is a little higher a 235 might work.
I'm running BFG 235/60 on 15" X 7" X4.25 "BS no trouble. If you want 8" you'll probably need 4.5" BS
Why 8" wide up front though? This going to be a dirt track car or something? A 7" wide rim can fit a pretty good size tire without looking balooney.
Edit: must be tired, that a 7" up front with 4.25 BS and 8" in the back with 4.5 BS.
Discussion Starter #10
would a 235/60-15 possibly fit on a 15x7 wheel with 4" backspace instead of 4.25" in the front?
More than likely, .25 or a 1/4" isn't going to make that much difference. I have room to spare to the fender lip even with the front springs cut a little.
Discussion Starter #12
cool, thanks.
yeah, i had a 15x8 with 4" backspace on the rear with a 235/60-15 on it, so i tried putting them on the front, there isn't a whole lot of space anywhere. even if i had 1/2" more backspace i think the 8" wide wheel is too much in the front.
i ordered a 15x7 with 4" backspace because they didn't have more than that. i'll post some pics when i get them in :D
thanks for all your help guys.
You really should measure, taking advice is OK but in the end you have to live with your decisions. I would bolt a rim up to the front before mounting any tires and have look see. Try to envision the tire on it and see how well the rim is centered. I really don't think like a lot of stuff all BS is consistent manufacture to manufacture even though it should be.
I took some pics for you, remember these are 15 X 7 X 4.25 BS up front w/ 235/60 tires. Rear.... 15 X 8 X 4.5 BS 275/60 tires.
Discussion Starter #14
Sorry to bring back this old thread. I just wanted to show off what I ended up with. I went with the 15x7 and 235-60 tire. The clearance is very close with the inner fenders removed. I may raise the coilovers or go with a 225-60 tire later on.
[/IMG]
When I had my keystones I ran the same width tire all the way around. I had to install some twist in spacers in my front coils to keep them from rubbing. They would still rub over some dips.
Discussion Starter #17
The most they had was 4" backspace without paying extra, so that's what I went with. I would have preferred a little more, but it wasn't cheap. It may fit better for someone else, my car is pretty darn low in the front.
With a 225 front tire I doubt it would be an issue.
LOVE your car zboggs! I plan on going with the same wheels on my 78. Did you go with the non-DOT wheels? Also do you have any overall pics of your car, I need some inspiration to finish mine, lol.
My 76
Hey guys,
I like these rims and I think I might get a set. Right now I have a set of rims from a 2003 Z06 Corvette. I had to use spacers and such and honestly it makes me a bit nervous. the fronts are 245/45/17's and the rear's are 275/40/18's. I had to cut the fender lips I little in the back to make it fit. I'd post a picture but can't figure out how.
Any way I was thinking 15x10's in the back with 275/50's? and 15x7 up front with maybe 225/60. I think 4 inches of back spacing front and rear would work ok with no rubbing? I want the wheel wells full and the car is not currently lowered but I am thinking of dropping it an inch front and back eventually. will this work or is hte backspacing a little off?
i agree zboggs car looks very tough i would also like some tech specs on that car suspension mods especially :yes: and pics
1 - 20 of 20 Posts
