Ok, unfortunately i haven't had the money for a while to do anything to my nova seeings how i'm stuck at a horrible paying job. I haven't done anything to it since last year when i had it painted and i replaced most of the trim, lights and such. It has Hotchkis 2" drop springs up front and 1.5" drop leaves in the rear with kyb shocks that are already going from the drop with only a couple hundred miles on them.
Since its been about a year since i've done anything i'm kind of getting upset. Yeah i drive it when i can, which has been pretty rare since it always seems like its raining all the time, and i really miss doing things to it.
So i've set a goal for myself for the winter, for sure i'm going to pull the subframe off so i can get to the firewall and smooth it to make it all pretty like, and while the subframe is off i would like to clean it up and such.
Ok so to the question, i'm thinking about replacing either the subframe entirely to save myself the aggravation of cleaning up factory welds and replacing it with a speedtech subframe or i want to replace the rear suspension with the Detroit Speed and Engineering's quadralink kit. The rear kit would by far be the cheaper route to go at about $1500 plus shipping if i couldn't pick one up at an event or something. The subframe however gets seen more easily with the hood open and i may see the advantages such as the weight savings, better suspension geometry and much better look, but that will set me back probably closer to $3000 or $3500.
Which would you guys suggest? If i do the rear i will definitely have to go ahead and put in dse's minnitubs, but i will have to save considerably more to do the front. Let me know what you guys think, i'm at a crossroads, i don't want to get bored because i have an intense passion for this car and it kills me thinking of all i want to do to it and i can't.
