Ok that helps. What do they fasten to? The reason I ask is because there were no inner fenders when I got it plus my LH front fender is smashed and I wanted to put the inner fenders in first before replacing that.
They fasten to the fenders and I believe the core support.
There should be 4 bolt holes on the core support, 6 for the fender side. I went down and looked at my innner fenders, I have 5 bolt holes on the front side, I'm not sure if the fifth on goes to the support or fender but you should be able to tell once you get it in place. It might be easier if you loosing up the fender first.......good luck.
Ok thanks for the info. Its going to be hard for the drivers side because the fender is pretty smashed. Does anybody know if the inner fenders are required for safety inspection?
