yes - you need too replace that unit (in u'r picture) ; as Adam says - - that IS NOT a :
Proportioning Valve !
It's called a "distribution block" - - which was added when GM started using the 'Dual M/C's ' to split
the front brakes from the rear brakes .............. and , have two seperate brake syetems (for safety) .
That's where that (distribution) block comes into play . (early years ,you didn't have 'That Valve' , using a
single style M / C ) .
I also bought the = more modern "Combination Valve" , from " INLINE TUBE " = with the M/C SS short
(pre-bent) lines .
info : Inline Tube - the 'Combo Valves' = are all the same (for different brands) mostly .
........... just the (pre-bent) lines are the difference . They sent me the wrong type lines
(different bends) ......... a simple phone call ........
and they took care of it ............ (I'd sure use them , again) .
For my set up - - (69 Nova - front drum to Disc swap) :
This was my stock brake (Disc) valves = using two valves : Metering (early style - Proportioning valve, &
Distribution block ) . . (the stock - factory set-up - in 69 ) .
Then , using INLINE Tube - use only one valve (plus , being NEW & not 50 + yrs old ) .
you get the idea . . . pictures are good =
# 1. - - stock - 69 , set up .
# 2. - - (this is showing = the Wrong M/C lines) ......... but , the same Combo valve .
# 3. = . . . I did have some 'spare brake line fittings' - I found JUST WHAT I needed too make my
brake lines fit the new (Combo) valve . I already knew about the "WeatherHead adaptor fitting" , for the rear
brake line position.
So , take your new valve to the 'auto parts store' (write down - or draw out ) , what you need & where
(position) , it fits .
= = look / ask them for their brake FITTINGS section .
Just find what extra (BRAKE LINE) fittings you may need. This made things alot easier .
.......... make sense .......... the Weatherhead (rear brake adaptor) fitting = # 7908 .
# 4 = Here's what I used . I 'bought that (Black) "Brake Light Tool" . . . but you don't need that tool' .
Simple - use Your TEST LIGHT - - (you may need a "jumper wire" = with 'alligator clips' ) . Too reach the + .
post clamp . Hook - up your Test light on the 'positive post' - (plus , side on u'r battery = "stick the point -
in the + batt clamp" . Then , "clip the other alligator clip - on the 'brake light switch' (on the combo valve) =
bingo .
I had my wife - pump up my brakes & HOLD them .
If the test light came - on .......... I knew the Combo valve HAD Tripped . = KISS .
You can Remove - that brake light switch - with out hurting anything - take a small screwdriver , and move
the brake light switch . . back too center . Then return too the brake bleeding .
note - you will need too "bench bleed u'r M/C 1st" - those small brake bleeding kits (with the plastic fittings
& small hose = works very good (at the auto parts store) .
I also find - - - too make brake bleeding easy - - - have some 'small' rubber hose (I use some clear hose -
so, I can see the brake fluid , going through ) - - - hook onto u'r bleeder screw - - - (open u'r bleeder screw) ,
and let the brake fluid gravity feed .......... into a small clear bottle . - - one wheel at a time .
Do this too each wheel ............ KEEPING your M/C = full of fluid .
Then , start the (real) brake bleeding .
You know all of this ............ Have Fun .............. we've been there - - .
jim
GM Proportioning Valve Front Disc Rear Drum – Inline Tube
I bought the ' Proportioning Valve KIT ' - - came with the mounting bracket & S/S brake lines : from
the combo valve too the M/C .
