1972 Nova
69-74 X-body (Nova, Omega, Ventura, Apollo, 68 is a possibility depending on options, as they had an option for a 4-piston caliper that doesn't sound like it was all that great). Possibly 67-69 Camaro. Anything else will need work or parts. You could buy a kit online for right around $5-700 with all that you need since these cars aren't really sitting around in junkyards in working order anymore.
66 Chevy II, 67 Chevy II, 65 C10
If it's first or second gen don't use donor spindles as your wheels will be pushed out 5/8 each side...get zero offset brakes
1972 Nova
I believe the disc itself will bit, but you will have to mill an area of the spindle down to be able to bolt the caliper bracket on. I personally would never pay that much money (on SS396 those have gone up to $325) for just a pair of stock rotors with nothing else.
This is a complete upgrade kit, with spindles and all. You can get it for $713, and if you want drilled and slotted rotors you can somehow get it for about $30 cheaper.
