What are you using for you disc brake conversions on your 63s. I will swap over to 5 lug when this happens.
yes right stuff is what on mine.Correct me if I am wrong ( and I know you guys will) but i think there is a bit more room in 66,67 fenders for tires, rims?
I have CPP zero offset disc brakes. I think The Right Stuff sells them as well.
I have a complete front end with disc brake conversion off of my 65' wagon that I'm not going to use going back. If you are anywhere close to SC I would make you a deal you couldn't refuse. I have no idea of the offset or whose kit it is but it worked fine with no rubbing on the fenders. Just an offer.What are you using for you disc brake conversions on your 63s. I will swap over to 5 lug when this happens.
sent you a PMI have a complete front end with disc brake conversion off of my 65' wagon that I'm not going to use going back. If you are anywhere close to SC I would make you a deal you couldn't refuse. I have no idea of the offset or whose kit it is but it worked fine with no rubbing on the fenders. Just an offer.
Do you have a part# on your CPP zero offset kit? And do you know the diameter with the caliper?I used a combination of CPP spindle designed for 64+ drum brakes and CPP zero offset disc kit
this kit is an 11" rotor, and uses an S10 caliper, I have 14" wheels and they just barely fit
I only have manual brakes and they work great, but this is not a high hp car, has CPP mini subframe kit and coil overs
its a whole other ball game if you are wanting 12"+ rotors and multiple piston calipers
I bought my setup a few years ago and don't know if this is still a working part number CPP 6267WBK-S.Do you have a part# on your CPP zero offset kit? And do you know the diameter with the caliper?
