I have spent two days on this and I am no closer to solving the problem than I was before I started. I took these springs that I am using off of my ’65 Nova two years ago. I have photos of the bottom of the coils sitting in the bottom of the coil shock with the ends sitting at the tabs. I didn’t take any photos of the top cup tab sitting in the holes but I know they were both sticking out of their respective holes. Looking at the spring cup tabs holes from the firewall perspective, the passenger side cup hole is on the lower left side of the shock hole closest to the firewall and the driver’s side hole being on the right top side of the shock hole closest to the radiator core support. These two holes are clocked 180 degrees from each other.
I bought new spring shocks and when they came in, I compared them to the originals that came off my Nova and they were identical. Both pieces were identical to each other also. I cleaned up the top spring cups and painted them for reuse. I have 4 of these and they all look identical with the top tabs being in the same location.
I read on another thread that the coil springs are suppose to be clocked opposite to each other being the end of the spring on one end sits 180 degrees opposite so the ends would effectively be at 12 o’clock and the other end at 6 o’clock. Mine do no sit this way. When I took the photo of the spring sitting up I sit it the opposite direction, my error but the results is the same. They are not 180 degrees from each other.
These springs actually show one end is sitting at 12 o’clock the other end at about 8 o’clock . See the photos. With the spring in place, I set the top of the spring cup in place and secured the tab into the hole with a vice grip so it was held in place. When I did this the bottom spring absorber bolts was nowhere near going into the two mounting holes on the top control arm.
So, I took the spring back out and turned the spring upside down and compressed it again. I sit it in the driver’s side and the same thing occurred. I move the spring over to the passengers side and the same thing. I know these springs came out of my car and were being use before I took them out.
Anyone got any idea of what I’m doing wrong here?
Please see my photos.
