I'm kind of on hold with my oil pump dilemma so I moved over to repainting the frame. Got it lined up as best I can and now its time to refer to the dimensions from the assembly manual to get it as close to home as possible. I am not 100% clear on where exactly these dimensions are referring. I can use a long rod into the frame/alignment hole and wiggle it around pretty good. Lot's of play there. Other than getting it centered and double checking some overalls on each side and a few diagonals, are there any tips or tricks that might help me locate this as correctly as possible.
You can see some dimensions in the pics and how they reference that dark line but I'm not really sure what that line is. Once I get this frame where it needs to be and torqued up, I can concentrate on getting the motor & tranny wrapped up and installed. I'm looking forward to that as a major milestone in this resto project.
