1973 Nova, TH350 Trans
What's the correct way to wire reverse lights and the neutral safety to a Hurst Shifter? (Pictured below)
I connected wires to the two terminals located on the shifter. I tested the resistance to confirm that the wires only engaged in the park and neutral shift positions.
I connected each wire to the purple and purple/white wires that were connected to the neutral safety switch above the steering column. The car starts in neutral and park with no problem.
I tried connecting the pink and green reverse lights to the shifter wires and the starter engaged instantly as I inserted the key into the ignition. What's the correct way to wire the reverse lights to a Hurst shifter?
