441 - 460 of 495 Posts
BradPenn
I know this has been mentioned before, but it's worth saying again. Brad Penn motor oil is the old Kendall Oil Company under knew management. Their products are all 100% pure Pennsylvania grade motor oil formulated for high performance engines. They understand ZDDP. Bradford, Pennsylvania is their home. Brad Penn is manufactured by American Refining Group Inc., 77 North Kendall Avenue, Bradford, PA 16701.
Here is a quote from the Brad Penn web site (link below).
In addition to our unique base oil cut, increased concentration of “zinc” (zinc dialkyldithiophosphate a.k.a. ZDDP) provides outstanding anti-wear/anti-scuffing protection for engines employing either ‘flat tappet’ or roller cams.
BTW, I just had my Inline 250 completely blueprinted by Portland Engine Rebuilders, and they provide BradPenn break-in oil. They specifically state that the use of any other oil during the break-in of a flat tappet engine will void the warranty. Antique and High Performance engines are their specialty.
http://www.penngrade1.com/
:confused:I know that this is an old thread, and I have read, and reread it a couple of times. But not being an engine builder or rebuilder, I still have a question.
First off, I have an all stock L48 motor with about 70K miles on it in a '71. It's in Wisconsin, and stored for the winters. So my driving temps would be maybe 32-90's.
From all of the info provided, it looks like the Valvoline VR1 racing oil is more than adequate for my application. So have been considering using the Valvoline VR1 racing oil, but not sure of the weight. It appears to be widely available in 20W50, and lesser so in 10W30 or 30W.
Is 20W50 too heavy for near freezing temps, and 10W30 too light for higher temps? And straight 30W too heavy for the low temps, and too light for the higher temps?
I'm leaning towards the 20W50 simply because of availability, but don't want to "hurt" the motor.
I know that any suggestions would be opinions, but thanks for any insight on this.
Sounds like you could use the 10W40. Brad Penn comes in that grade, I've been using it for about 4 yrs. now.
Brad Penn correspondance
:DI had a very informative conversation with a Ken Tyger of American Refining Group, Inc. this afternoon. They are the makers of Brad Penn oils. This is posted here with his permission. Feel free to contact him with concerns or questions.
Frank,
It was great speaking with you this afternoon. Please allow me this opportunity to share with you some thoughts from our discussion earlier.
Regarding the lack of American Petroleum Institute(API) Service Symbol “Donut” and Certification Mark “Starburst”, there is no need to formally register a product with API since there is no intention of putting a ‘donut’ on the bottle. To further explain…an end user/customer will not find an API Service Symbol (Donut) on any of our Brad Penn® Penn-Grade 1® High Performance Engine Oils due to one very specific reason: their enhanced AW (anti-wear) chemistry. This formulation enhancement meant that specific component levels, specifically Zn (Zinc) and P (Phosphorus), exceeded the limits of the API platform they were designed on. However, these enhanced formulations still had the performance of the aforementioned in terms of detergency/dispersant, anti-oxidation, rust and corrosion. If we were to “license” our Brad Penn® Penn-Grade 1® High Performance Engine Oils, our Zn and P levels would be limited (guidelined) to meet specific API specifications. This approach meant that the Brad Penn® Penn-Grade 1® High Performance Engine Oils do not conform to API and ILSAC standards. We certainly have other oils in our product line “licensed” and carrying the API donut. The Certification Mark “Starburst” I referenced in our conversation identifies the oil as meeting the current International Lubricant Standardization and Approval Committee (ILSAC) engine protection standard: ILSAC GF-5/”Resource Conserving”. Engine oils meeting this standard will carry the “Starburst” as well as the latest API Service category SN.
It is important to mention that the Brad Penn® Penn-Grade 1® High Performance Engine oils were designed and tailored specifically for the needs of the classic, muscle and street rod “legacy” cars that incorporate a flat tappet cam. They are NOT intended/recommended for applications equipped w/ catalytic converters (post-1975). When an application utilizes pollution control equipment….such as a catalytic converter….the oil must be formulated to be compatible with the exhaust catalyst (lower phosphorous to avoid catalyst ‘poisoning’). Modern passenger car engine oils are a complex mixture of additives and base oils that are required to provide good engine lubrication and increased fuel economy while reducing emissions. They accomplish these goals in a number of ways including utilizing lighter viscosity base oils, higher concentrations of friction modifiers and reduced levels of certain functional additives. Unfortunately, these same characteristics can have a negative effect upon oil in numerous applications. Stricter emission requirements have caused the need to reduce the amount and type of anti-wear agent used in the oil (ZDDP – zinc dialkyldithiophosphate) in order to lower the oil’s phosphorous content and help prevent catalytic converter ‘poisoning’. This has raised questions about the ability of newer engine oils to provide the needed anti-wear protection to critical engine parts.
In addition, the additive element that is controlled in motor oils is phosphorous, not zinc. High levels of phosphorous in motor oils are detrimental to the components of the catalytic converters used on today's modern vehicles to reduce emissions. Therefore, to minimize catalyst 'poisoning' the American Petroleum Institute (API), the very organization that sets the standards for engine oil quality and performance, has established limits on the concentration of phosphorous in engine oils designed for use in vehicles equipped with catalytic converters. Zinc and phosphorous are integral elements in the anti-wear additive used in motor oils so when the phosphorous concentration is reduced the zinc also is reduced. However, because of the chemical composition of ZDDP, the zinc concentration in motor oil will typically be slightly higher than the phosphorous concentration. Oils meeting the most current API 'SN' category that also meet the ILSAC GF-5 classification and are considered 'Recourse Conserving' have phosphorous concentrations that are limited to 0.08% wt maximum (800 ppm). In comparison, the unlicensed Brad Penn® Penn Grade 1® High Performance Engine oils have a typical phosphorous concentration of 0.140% (1400 ppm).
So you see Frank…modern engine oils have seen a drastic reduction in the amount of AW chemistry…mainly to protect and extend the life of the catalytic converter. Because of today’s emphasis on fuel economy and emissions, modern engine oils have been “updated” accordingly. Although these very same modern oils are designed to be “back-applicable” to the older legacy applications, that doesn’t necessarily translate to being the “right” oil. This is specifically the reason why our Penn Grade 1 High Performance Oils, with their enhanced AW chemistry and PA Grade Base Stock, are ideally suited to protect the flat tappet cams/engine components of the legacy, classic, pre-catalytic converter equipped cars (pre-1975).
I’m sure I have forgotten to address something we discussed. Please contact me if I can be of further assistance. In the meantime, please visit our website at www.penngrade1.com to learn about our company history, high performance product line and if interested, the many testimonials offered.
Regards,
Kenneth M. (Ken) Tyger, OMA I, OMA II
Oil Monitoring Analyst
Sr. Technical Services Rep.
77 North Kendall Ave.
Bradford, Pa. 16701
(814)-368-1210
[email protected]
Valvoline VR1 Racing oil
I've been using the valvoline VR1 Racing oil and have had no issues and I spoke to others who us it also. I spoke to others who also use it with no issues what so ever.
Well thats what I run and its fine. Rotella T 15w40.
I did too, up until last year. I will be switching to Mobil 1 now that Rotella has changed for emission purposes. I've been running Mobil 1 in our flat tapper race engine for 3 years now with no issues, so I'm going to start using it in my BB now too.
shell makes one
A reputable engine builder in my area told me to use Shell Rotella T after he rebuilt my engine (with new cam). Its an oil for heavy duty diesel engines but meets all the additive concerns noted here. And it is very reasonable priced.
10w30 and I have had no troubles in 3 years now.
ZDDP has been removed from Diesel oils also.
No protection with today's diesel oils, been this way over 4 plus years.
:yes::yes::yes:
Great product, I use the 10W-40 which no one else makes in that grade with ZDDP. Been using for 4 or 5 years now. Zinc and phos is a must, and with Brad Penn you get the added benefit of Pennsylvania crude, which is the best motor oil lubricant to start with.
