Each paint company is going to be different in the amount of flattener to add.
There is often more than one flattener within a brand also. The paint jobber should be able to mix it to your needs. It is you preference as they were not all the same form the factory. I have sprayouts of low gloss blacks I use for different things, I may not always use the correct one but I use what I like.
With a base clear you only flatten the clear. With a single stage you have to put on at least two wet coats to get it to flatten right, Too little film build will
cause it to be glossier. I also never force dry, let it air dry slow.
