1 - 3 of 3 Posts
I was kind of hoping to run 3 point seat belts in my first gen build but I don’t really see a prevision in the frame area under the headliner accept for a chintzy little sheet metal tab. Anyone running these in there first gen ?
66 Chevy II, Pontiac powered; 68 &75 Firebirds
3 point
The provision for the 3 point mount in the roof wasn't added until late '66 and in '67. My 66 did not have it, so this is what I did based on info and pics from the forum. Gen 1 should be similar. I got the belts from Morris for a '67.
First pic is an OEM '67
Second pic is the plate I made.
Third pic are the holes I drilled and the slot cut to slide the plate in.
I opened up the slot to slide the plate in, then welded to the sheet metal. Tapped the slot closed n welded up.
1 - 3 of 3 Posts
