1 - 3 of 3 Posts
This site has come through for me in the past. I am looking for the cover that closes off this opening. What I got from Classic was a foam cover that seemed more like it goes on the inside of the firewall. Look forward to your responses so I can continue with finishing the firewall work. Thanks
There is a two piece plate that goes on the inside that then presses against the foam gasket you have.
The plate above looks like it does not come with the mounting bolts but they should be available and will have an integral large fender washer on them. The plates have oversized holes on the firewall area to where this allows the plate to be shifted up,down, left, or right to keep the column in alignment with the steering box. If you ever change the subframe mounts then this plate must be loosened to where with the new bushings, the plate will probably in a slightly different spot
The plate also has two screws to clamp against the column itself.
1 - 3 of 3 Posts
