1 - 20 of 117 Posts
My 76 nova is shaping up nicely. I have spent only $60 since its initial purchase ( $400 )
The 78 firebird is steadily donating parts.
Today I looked into swapping in the nose piece, but it looks like it is too narrow. I am entertaining the prospect of sculpting a 'bird' nose from steel. Could look nice if done well. I would also increase the number of headlights from four to six! That is a mod I always wanted to make to the bird. ( ok, a nova has two, so it would be from 2 to 6 ):LOL:
About all I really accomplished today, was to fabricate a new body mount for the left side radiator support/crossmember. The old mount was long gone, and the front steel was just hanging on the fenders.
Also today, swapped in the fan motor from the bird, and looking into using the inner fender, pass side. Not a perfect swap, but it doesn't have to be perfect, just has to work. Tomorrow, will try to get that fender back on ( beat out some dents while it was off ) with the inner fender in place. Will also need to figure out something for the battery tray.
Would I be better off to leave the condenser in place ( not going to run AC ) or remove it as a restriction of airflow? I guess it being in place it protects the radiator?
Will also try to get some pics of the fabricated body mount. It's ugly: I cut the pieces from a sheet of 16 ga with the gas axe, and didn't clean up the edges, nor paint it. Real rat rod quality I guess. BUT.. that 16 GA will out last the rest of the radiator support to rot anyhow.
Also using the body bushings from the bird. that car was in SUCH good shape before the ol' lady wrecked it! I am considering swapping in the rear axle and front discs, if they'll go. Then I can run the snowflake wheels ( will have to get a new one. The front left is destroyed.. in fact is apparently warped so bad that it would not come off the studs! )
Does anyone know the compatability of 77 firebird brake parts to a 76 nova? The very astute of you will notice that at the front of this article, I mentioned the car to be a 78. TRUE that, but the suspension is all from a 77. And what about the shocks? They were brand new on the bird, but she might have blown the seals taking it thru that ditch.
sorry if I am boring anyone to tears, but it is just nice to get working on a car again.
Got the metal back on the front. Turns out the pass side mount is a tad high, and the drivers side is a tad low. Shimmed up the drivers side, and going to let the other side ride. it sits better than it did, anyway.
Today got the frame done for the SIX rectangular headlights..
dam this is going to look tough!
Discussion Starter · #6 ·
I got the lights frame welded in yesterday.
Today I got the buckets modified. Cut off the old adjuster tabs, and welded on new tabs. Shot it with gloss black.
Got the headlights mounted, not sure I like it. Ran out of light to get a good shot of it.
Discussion Starter · #8 · (Edited)
I totally did not like the way the outside lights sat on the frame. They were too far forward. So I cut the frame, cut a recess for the bucket, and welded the frame end onto the crossmember. The end lights look much better.
Why does everyone that looks at it say MAD MAX :devil:
Still need to wire the extras. Going to use a relay fired off the highbeam circuit. Take the power straight from the power junction, else the battery.
i totally did not like the way the outside lights sat on the frame. They were too far forward. So i cut the frame, cut a recess for the bucket, and welded the frame end onto the crossmember. The end lights look much better.
why does everyone that looks at it say mad max :devil:
wtf!!!!!!!!!!!!!!!!!!!!!!!!
Discussion Starter · #19 ·
Started a new job, don't have time to work on it right now.
Interior is a mess. Someone tried to recover everything in white, but apparently didn't have hog ring pliers / know-how because it is unfinished. And must have been left with windows down for a while cause it is a bit moldy. The headliner is hanging down, but was obviously replaced with same material.
At this point, I would rather fix or replace the old tail lights just for time's sake.
BUT.. I do have a set of 72" side pipes sitting around.. only question is do I make them both live? The stright six would breathe just fine through one side.
1 - 20 of 117 Posts
