1 - 2 of 2 Posts
I have 350 I'am trying to put twin spal fans in and i cant get the bolts in the head out for the sensor .It has a edelerbrock rpm airgap the front holes have the heater hose and temp gauge in them on the back it has the crossover holes plugged up can i put the electric fan sensor in that hole? I did not know if the flow there and location is okay Thanks for any help
If you can't get the by bolts I am assuming you mean the square drive pipe plugs in the head out it will be fine to put them in the manifold that is where all the tbi injected motors put the ect sensor but before you do that try heating the head up around the plug with a torch and putting some pb blaster on the plug and let is soak. If that doesn't do the trick try some parrafin wax on the pipe plug and let is melt in. And apply steady pressure when trying to remove the plug. I have had good succes with these methods. Good luck!
1 - 2 of 2 Posts
