Will any fan clutch work properly in either direction? I want to use one with my serpentine set up w/reverse rotation. If not, what GM application uses a reverse rotation fan clutch. Most serpentine systems I've seen uses an electric fan. Thanks for any help.....Lynn
Lynn, not sure if it'll work opposite direction, but what are you going to do about a fan? Just curious. I've got a clutch fan also, but car isn't running yet. Soon I hope. Dave
Dave, Locating a fan doesn't seem to be a problem as they are available most anywhere, parts stores, Summit, Jegs, etc. I just can't seem to locate a clutch that specifies reverse rotation or counterclockwise. I'm running a serpentine system with a Spal "puller" electric fan (thermostat controled) with no cooling issues, but it's pretty noisy so that's why I'd like to switch to a clutch fan. Thanks for your input, though. Lynn
Discussion Starter · #5 ·
I use a reverse rotation clutch and fan on my GM belt drive set up. Its a "nonthermal" type.
Not all can so you need to make sure you get the correct one.
Think this is the one I used but could be wrong, got it from Advance Auto parts.
http://store.summitracing.com/partd...&part=DER-21037&N=700+-79576+115&autoview=sku
Mike, Does your set-up seem to work like it should, at idle and highway speeds? I run an electric fan now (thermostat controled) with no cooling issues, but I don't really like the noise of the fan. Thanks...Lynn
absolutely
Yes it works great. Prior to this I ran an 18" flexalite but got tired of the noise. With the clutch and 18" Derale fan it now runs about 5* cooler, go figure! Never gets hotter then 185* even on round robins at the track.
Get the largest fan your shroud will allow, assuming you have one. If I remember right stay about 1" smaller then the diameter of the shroud.
