1 - 9 of 9 Posts
Whats a set of factory 67 disc brake setup worth. Includes spindles,rotors,calipers,pads and caliper bracket. No backing plates or steering arms. 0 miles on fresh turned rotors. just wanna get a idea on what they might be worth.
Thanks in advance.
Vendor
Should be worth a fair amount to the right person if they are in good shape.The 4 piston calipers were a bit troublesome and the two piece rotors have not been made for years.Very rare stuff for a 67 Nova!!
Thanks in advance.
What's the condition of the parts? How thick are the rotors. .970 is the min to use. Must use calipers to check. Do you have part numbers/pictures of the set-up? Calipers leaking/need rebuild?
Dave
67 Nova Boy
Well after both of you guys description, I don't have a factory set up. I have one piece rotors and single piston caliper. I must have been a aftermarket system.
Banned
post up some images... very possible we can identify the parts for you and get you an idea on worth. just because it's not a factory set up doesn't mean it's not worth a few bucks...
let's see what ya have ;)
Banned
probably an old CPP type Chevelle set up... it moves the wheels out due to rotor dimensions. doesn't appear to be a "Zero Offset" type kit.
rotors, brackets and calipers, complete set up, used... i don't know if i'd include the spindles as whoever needs/wants it will already have spindles and can mill/cut down the boss themselves. i think i'd offer the spindles separately.. or if you want to unload everything at once, i'd say 'bout $175.-$200.00
Thanks Flyer!! The spindles are the disc style, I compared them to the drum spindle I took of and the boss is lower than what I took off. I'm not sure if I wanna sell or not. I really want a set of aero space or wilwood's brakes bad!!
Again thanks Flyer!!
I have a complete set up that has been stainless steel sleeved, including the master...New two piece rotors are now available on eBay, both US made, quite pricey, and Chineese made also!
1 - 9 of 9 Posts
