I have a Chevy 350 in my 72 nova.
My issue is I have the most extreme sounding backfire that I’ve ever heard. It’s as loud as a gunshot. Let me tell you what I did and see if you can help me figure out how to get back to when it was working fine.
So my car was running just fine until 2 weeks ago when I decided to convert from a th350 transmission over to a 700 R4. I was told when you pull the transmission that the engine may lean back and damage the distributor. So I took the cap off, hoping that that may, keep me safe from that issue. When I put the cap back on, it didn’t really seem to sit in the same place that it had before. But I snapped it back on anyway. HEI by the way.
I really tried to limit what I changed during the process so that if there were any issues, I would know where to look. But I definitely have a problem.
The car seem to start just fine. But I noticed originally when I started it that the passenger side headers seem to get significantly hotter than the driver side headers. And then I fired up a second time and the extreme back fire started it was so loud that it scared me that it sounded like it would be doing damage and I turned the car off immediately. So I haven’t really got a chance to let it run for more than 15 to 20 seconds.
1. do you think that I somehow messed up the timing? in my very limited experience that’s all I can come up with. And or is it possible that maybe I also messed up the distributor itself. Or something that I don’t know about because I really don’t know much about any of this. And just wanted to get your guys thoughts. I’ll try to make this is short as possible in the hopes that you are still reading and you all might be able to help. Thank you so much.
When I did the swap, I really tried to isolate what I did to adjust the transmission. Because I don’t know anything about timing and all that so I tried to not mess with it. So I thought just taking the cap off and putting it right back on wouldn’t be a big deal. But maybe it is.
I will monitor this thread closely. If you have additional questions, they can help me troubleshoot this I would really appreciate it. I was just trying to go to this really cool car show next month. It’s at an airport and it has planes and cars. And I thought I would have time to do this transmission swap. But now I’m very worried that I either won’t be able to finish it or that I did damage.
thank you
ryan
thank you
ryan
