I've always been a fan of Remflex gaskets, they seal well because of the material they use.. Used it on a 4 cylinder NA build I have and they've been great so far after 2-3 years of track time.
Found this hairline crack in manifold do you think it will hurt. Not in two. Also the donut looks like toast. I believe it was the worst noise maker. Grey Wood Trunk Road surface Automotive tire
Automotive tire Wood Door Gas Fixture
the manifold gasket looked pretty good to me.
Sorry, I thought you were asking about a gasket at the head. YES! I would replace that gaskey. It's probably going to leak like crazy. That crack doesn't show any evidence it leaks. No black residue present. The right welder could weld that up if it leaks. Fixing that donut leak might make the exhaust look for the easiest crack. You know after the other is sealed up.
