Hi everyone....
Getting closer but the pace is slow......
I installed my 2.5" exhaust tonight........ aligning, tweaking, aligning, and tweaking some more.:D :turn::turn::bored:
What do you recommend as the minimum clearance between the exhaust and the floor board and drive shaft? I've got it set at about 3/4" from the floor and DS.
Also, I will need to do something special with the passenger side where it connects to the collector. The pipe is right up on the bottom of the trans x-member...... Have any of you had that issue? If so what did you do about it?
I have the summit headers and exhaust.
Thanks in advance..
If I recall correct I had to weld in an extension into the exhaust on the pass side. I have Summit 2.5 pipes and Hooker headers.
Funny how parts made for this car don't work on this car, huh?
I hear that one..... for this car and 32 others.... :D:D
Do you have any pics of your pass side exhaust??
