Hey all, it's been a while since I've been on here mainly because the Nova's been mothballed. Well it's time to get it back out and I'm considering changing the transmission and rear gear in an attempt to get more use out of the car.
I was orginally thinking about using a 200-4R but it's more money and there is more to change to install it. So I started looking at the T350 and it seems like when you do the math I should get roughly the same performance as the PG if I use 1&2 for racing and have a more sane highway rpm in 3rd.
Here is the current combo that has gone a best of 11.62 @ 118 with a 1.6 60'.
327 .030" over
stock block, crank, rods
forged flat tops with 2 valve reliefs
461 casting ported heads
252/260 @ 106 .540 int, .547 ex at the valve
380 ft lb from 4500 to 6000
435 HP at 6750
shift at 7000 and going through the lights at 7000
The converter flashes to 4400 off idle
PG
Manual valve body
turbo spline
9" with 4.56 gears
6 pt cage
frame connectors
cal tracs
stock monoleaf
235/60-15 hoosier quick time
The only change I want to make is to go with the Turbo 350 and 3.25 rear gear and slightly taller 255/60-15 while using the same converter. Another factor here is that the rear end is howling and needs a rebuild so if I'm going to make a change now would be the time to do it.
At this point I am not concerned with all out performance but have good performance with the ability to drive the car to the track 40 miles away rather than towing or running 3800 @ 60 mph.
Here is the math on the comparison.
starting line ratio
PG - 1.76 x 4.56 = 8.02
T350 - 2.52 x 3.25 = 8.19
rpm drop 1st to 2nd
T350 = 7200/4343
PG = 7200/4019
Using 1 & 2 - 1.52 x 3.25 = 4.94 final drive and 27" tire =
7500 RPM 122.71 MPH
7000 RPM 114.53 MPH
using 3rd on the highway
2500 RPM 62.17 MPH
It seems like if I use the T350:
- cheaper than 200-4R
- less weight than 200-4R
- similiar results using 1&2 as with the PG
- use same converter from the PG
- still have a reasonable highway rpm
What am I missing or does this actually make sense?
Thanks in advance and sorry for the long post.
PB
327 .030" over
435 HP at 6750
PG
Manual valve body
turbo spline
9" with 4.56 gears
6 pt cage
frame connectors
cal tracs
stock monoleaf
starting line ratio
rpm drop 1st to 2nd
T350 = 7200/4343
PG = 7200/4019
7500 RPM 122.71 MPH
7000 RPM 114.53 MPH
2500 RPM 62.17 MPH
PB
