1 - 10 of 10 Posts
Engine Vin Decoding Help
I have a 1974 Nova Hatchback, What I'm finding says it's a V6 but has a V8 in it.
Here's the Vin #: 1Y17D4L205121
Block Casting #: 3932386
Engine ID #: V0925WI
Ok then. Anyone decode the block vin? Also how can I tell if it's the original engine that came with the car?
Heres what I came up with on the engine code.
# 3932386
Year 1969
Engine size 350
Horsepower 300
Used from August 1968 until approximately January of 1969 when replaced with 3956618. Used only as 4-bolt block.
Congrats on the 74. Give it some love!
EDIT: Heres the ID decoded.
V0925WI
V = Flint Engine
09 = Sept
25th = Day
WI = 1969 350
Great links, tons of info about the vins. How can I tell if the engine and tranny are original?
Engine is not,it from a 69.
# 3932386
Year 1969
Engine size 350
Horsepower 300
V0925WI
V = Flint Engine
09 = Sept
25th = Day
WI = 1969 350
+1 I gave you the info and it specifically states 1969 along with the exact date of production from the ID number for the engine.
On the other link it shows you what your Nova originally came with. You did not read the page. Say it right there...
Engine Type = Turbo-Thrift valve-in-head
Displacement = 250 cu. in.
Cylinders = 6
Bore & Stroke = 3 7/8 & 3.53 inches
Compression Ratio-Std = 8.25 to 1
Now the tranny on the other hand may be the original if its a 350 Turbo Hydramatic. No way that I know of to tell if the tranny is the original.
1 - 10 of 10 Posts
