This is example how something simple can cost you big!
This is what happens when a engine is not ventilated correctly.
This engine used a lot of oil in a 300 mile run on the hwy.
Lost oil pressure and major repair. owner elected to replace the engine.
Please take note of the 2 PCV valves, They are not even hooked up to a vacuum source. They are in both valve covers. And do not allow air in, and restrict air flow out.
this was a big mistake, as the engine must have air in and out. The ventilation process reduces crank case pressure. High crank case pressure causes leaks, blows gaskets and causes high oil consumption as in this case.
YOU MUST HAVE FRESH AIR IN, and a positive controlled Vac source to ventilate the engine.
This engine had no vent, no vacuum source. The old valve covers were plugged with a PCV valve each without a vacuum source.
If this had been a original 327 with the block vent out the back the engine would have been ventilated. This is a 350 engine and no vent.
Also take note of a copy from a Motors manual on how the engine vent system works.
