Most of the aftermarket front clips that I’m aware of do not make provisions for the manual clutch linkage assembly. I have had a couple of TCI clips and neither clip had any bracketry for a bell crank. If you plan to run the manual clutch linkage assembly you’ll be fabriting your own mount and modifying bell crank hardware. Alternatively, you can switch to a hydraulic clutch system.
I’m going to be running a V8 F body T5 in my next car and the clutch will be actuated hydraulically with OEM F body hydraulic master cylinder a components.
