I recently put in a Thumpr cam in my 350. spare me the "oh what a ****ty cam" crap. i dont care.
Im trying to figure out the surging problem I'm having. held at about 1500 rpm the engine will rise to 2000, down to 1000 in about 3 second cycles. idleing it does the same thing, except it will go so low it will almost die (and die in some cases) I have an edelbrock 1400 carb.
My timing is set @ 24 initial with no vacume advance at all (disconnected) and heavy springs on the hei mechanical advance, which wont allow timing till 3500 rpm (2 degrees). I dont BELIVE i have any air leaks, and used new gaskets when reinstalling the intake manifold, which I torqued to the proper specs.
I have full exhaust and the engine is a stock gm, heche in mexico.
Suggestions?
Thanks in advance
Suggestions?
Thanks in advance
