Is it in the car or out? if in u can use stuff called engine flush, ive heard some people use kerosene. good luck.
Just remember anything that gets cleaned off drops into the oil pan. Anything in the oil pan gets pumped thru the bearings (unless you've blocked off the oil filter bypass). Sometimes things are better left alone until done right.
