So we have ripped out our old 307 and were attempting to drop in the new 350 we bought, but we ran into some technical difficulties. We plan to drop in this new 350 with our 1968 muncie four speed in a 68 Nova. We are not completley aware of the year this 350 block was produced. I have attempted to research the casting numbers (3970010, V02038WK, A118) <-- those being all numbers found on the block but with no straight forward answer.
Anyways, we went to attach the bellhousing and clutch assembly, but ran into a few issues that maybe someone will be able to guess a date for the motor, and what we should do...
#1 we went to attach the bellhousing but the 68 bellhousing from the 307 had a 6 bolt pattern, where the block as a 7 bolt pattern...
#2 The starter on the new block has offset bolt holes and did not fit into the 68 bellhousing. When you put the starter through the opening the holes would not line up, and if you lined the holes up the fly wheel was too small and would not reach the starter.
#3 We had a bigger flywheel that came with the engine block, but it is too big for the 68's bellhousing. And again the starter will still not fit in the bellhousing and line up with the holes
I found a guy who is selling a bellhousing that will fit up to an 85 block, but im still unsure if this will fit. I really wish I could figure out the specific year of this damn block so this would be a lot easier. Any help would be awesome and I apologize if this is difficult to comprehend. Im frustrated, I have a car now that is immobilized, and its late haha, But I guess that is what makes everything fun in the end right.... We will see
