62 nova I bought has power brakes, I want fender well headers more than power brakes I know sounds ridiculous but that’s what I want, I’m not touring in it ever or road racing, I want the fender well look, my question is will the master cylinder with booster attached work if I remove the the booster or should I buy a aftermarket original one ?
I would look at the pressure and pedal ratio if removing the booster. I took mine out for a different reason, putting everything under dash, and offer some analysis on master cylinder with "constant" of 6 to 1 pedal ratio and 100 psi being applied at pedal
3/4" master cylinder = 1359 psi
13/16" master cylinder = 1158 psi
7/8" master cylinder = 998 psi
15/16" master cylinder = 870 psi
1" master cylinder = 764 psi
1-1/8" master cylinder = 603 psi
The less output pressure the greater the leg workout you get trying to stop the car
