I have a dual Spal 11" electric fan in my car. For some reason (I'm wierd?) it makes me nervous when my fan runs longer then 10-15 minutes at a time. I guess my question is- On a hot day (85-95 degrees outside) is it normal and OK for my fans to be running 30-60 minutes at a time if it needs to be?
I have a on at 195 off at 175 Spal thermostat hooked to the fan and a 185 thermostat in the water neck housing.
I am running a 100 amp alternator, NO air, radio, head lights or electic water or fuel pump.
The car does not run hot or anything. no problems other then me feeling like the fan motors are running too much and will get burned out......
