1 - 10 of 10 Posts
Picked some tubular control arms off ebay for about $270. I also have a set of qa1 coilovers to go with my set up. Now im trying to put everything together and im a bit confused about how everything is supposed to line up. The control arms seem like they are supposed to line up in a different location and the angle is weird. Im new to this so maybe i dont know any better. Could someone tell if this is right? The coilover dont line up as well
Control arms
Discussion Starter #2
Ok after reading over the ebay listing i found some conflicting info. They state that the arms fit any A body. But i was under the impression that the novas are x body. I sent the seller a message and u hope to get this resolved asap
Mike - 74 Nova Baltimore, MD
A-Body ebay tubular control arms usually have a gold colored cross shaft with no inserts.
404454
Your control arms look correct for an X-Body (3rd Gen Nova), but it looks like you have the lower tubular control arm installed on the wrong side of the car... lower arm in your photos should be on the drivers side. IIRC, the red bumper on the lower control arms should be closer to the front of the car... under the sway bar (yours is closer to the back of the car). Below are a couple images of the correct installation.
404451
404462
Your upper control arm looks like it is installed on the correct side of the car.
P.S.... If not done already, it is also highly recommended that you replace the ball joints that come with the ebay control arms with high quality replacement ball joints. There are several post throughout many car forums that discuss the inferior quality of the ball joints that come installed on the ebay tubular control arms.
Ok. Thanks for the reply. I hope that helps my situation. I will switch them now. When i was installing i wasnt too sure about let and right.
As RifRaf stated, the lower control arms are installed on the wrong sides. The red Bumpstops need to make contact with the landing point welded to the chassis.. It will be obvious when you push the lower control arm up to the chassis and see the red bumper is on the opposite side of the spring cup..
Man yall saved me. I was losing my mind. It sucks if i have to change the ball joints. That wa ms one of the main reasons i got this setup. Oh well. They are cheap for a reason
Ok. Now that that had been addressed and corrected. Is there a base adjustment for the shims on tbe upper control arms. When i got the car the whole front end was tradhed. No shims or anything. The car was a hassle. Bolts falling out and the steering coupler bolts fell out. So i cant even turn right now.
Is there a base adjustment for the shims on the upper control arms.
There is really no "base" adjustment for the shims used on the upper control arms... each car will be different (my Nova required a different shim pack from the left side to the the right side on the upper control arms).
Once you are done putting the entire front suspension together and the car can be driven, you really need to get a front end alignment.
Putting a couple shims on the front and rear bolts holding the upper control arms (as shown in your photo) should be enough to get you to the alignment shop.
404464
Below are some recommended alignment spec when you take your car to an alignment shop.
Castor
Driver: 5° Positive
Pass: 5.5° Positive (.5 more to help with road crown drift)
Camber: 1/2° negative (both wheels)
Toe in: 1/16"
Don't use stock alignment specs for a 1974 Nova... as they were meant for bias ply tires.
It sucks if i have to change the ball joints. Oh well. They are cheap for a reason
You don't have to change the ball joints... it is just recommended to do so.
If you do decide to change the ball joints, I highly recommend that you install the Proforged 1/2" taller upper ball joints (along with Proforged... or Moog... or other quality name brand regular lower ball joints).
The 1/2 taller ball joints installed in the upper control arms are going to improve your camber gains (provide a negative camber gain) while the suspension is under load during a turn.
Proforged Tall Ball Joints 101-10016
This is what I did when rebuilding my front suspension. Below is a photo of my rebuild with tall upper ball joints. Note: I added a piece of black heater hose (prior to installation) to cover the exposed portion of the ball joint stud between the boot and the steering spindle - see arrow.
404465
While your at it, you may also want to think about changing your tie rod ends to "Taller" tie rods ends... as this will help with the "bump steer".
Proforged Part# 104-10529
Discussion Starter #10
Ok. Ill do that. Theres a firestore around the corn
Ok. Ill do that. Theres a firestone around the corner from me. Ill ask them if there able to do it.
1 - 10 of 10 Posts
