1 - 11 of 11 Posts
Whats the best way to remove the E brake cable from the drum brakes and then get that "expanding" mount out of the hole where it goes through the backing plate?
I have a piece of tubing, I have had it for years. I slide the tubing over the one way lock, collapsing the lock and releasing the cable.
If your deleting your e-brake, remove the cross bar and swing arm on the shoes.
Al
Vendor
A fuel line sized hose clamp work well also.Put it on and tighten it and then pull out the cable.
I have also used a open end 9/16 wrench the boxed end of it over and a solid pull...POP but the hose clamp always works !:yes:
There are pliers made to unlock them. Since I dont use them often I picked up a cheapy set at Harbor Freight.
A fuel line / mini clamp works the best and a little rust /nut buster lube and they wiggle out for re-use. I agree !:yes::yes:
1/2" box wrench slides right over and compresses the barbs and it will pull out.
1 - 11 of 11 Posts
