I am redoing a Nova, it is blasted and ready to finish. I purchased a case of each of the following paint in cans from Eastwood.
Rust encapsulator
( black)
Under hood black
Chassis black
and 1 can of Seam sealer.
I have been told to put the rust encapsulator over the bare metal and then the Chassis black over that. I was going to use this on the subframe, firewall the underneath of the car.
I then thought I may just use it on the subframe and use the under hood black on the bottom of the car and firewall.
What have other people done. I was told to put the underhood black right over bare metal, is this correct? I have been told to put the seam sealer over primer, not on bare metal. I have been told not to put chassis black over etch primer. As you see I have been told alot of things to do but would like to know what has worked for others before I get myself in trouble.
I am leaning towards blast, prepsol, etch primer, underhood black for bottom of car and the firewall, seam sealer over primer then under hood black over that. What do you think? Then blast ,prepsol, black rust encapsulator, chassis black on subframe. Does anyone know the correct way these items go on and work? I have talked with three different people at Eastwood and all three have told me slightly different ways they should be applied, but none had actually used them on a project of their own. Please HELP!!!!
Rust encapsulator
( black)
Under hood black
Chassis black
