I used the cheapest summit kit. I had a lot of problems with it. wrong banjo bolts, bad calipers. The caliper brackets needed ground down. It was SSBC parts. It works great now, and I was given about 25% back in a refund for bad parts, but it was a huge hassel. If I were doing it over again I would do a search and spend a little more. JMO
I bet my CPP kit was twice as bad as your summit kitI used the cheapest summit kit. I had a lot of problems with it. wrong banjo bolts, bad calipers. The caliper brackets needed ground down. It was SSBC parts. It works great now, and I was given about 25% back in a refund for bad parts, but it was a huge hassel. If I were doing it over again I would do a search and spend a little more. JMO
