Has anyone done this conversion using the DBK1012LX Kit? I am in the process of this conversion and clearly the cables sent are not a factory replacement. The factory cable to the drums is a continuous cable that from the pull point is approx. 24" on the left side and around 58" on the right side. The kit gives you 2 37" cables so clearly one is too long and one is way too short. Without some major mods to make this work has anyone ran into this issue and did you just reuse the original cable? Thanks.
