I have a 67 coupe and i need to shorten my drive shaft. Can some one tell me what other years or models share the same driveshaft as the 67 Nova
If you're going to have it shortened, most any driveshaft that is longer than your final cut will do. How much are you trimming off?
The most convenient driveshaft to use is one from a Vega, any year. This will bolt right up to your rear end yoke and slip into the tranny. You can also use a stock driveshaft from a 70-81 Camaro or Firebird. This is 3" shorter than the stock Nova one but will require an adapter u-joint in the rear. You can get these u-joints from most auto parts stores.
