On my 64 2d Ht the drivers door works (opens) with the inside and outside handles, but will not lock from the outside. It will lock from the inside by pushing the door handle down. The lock cylinder assembly turns with the key, (quite freely) but will not lock the button. Any ideas on what is causing this? I am having problems getting the door panel off to check out what's wrong. I took the crank, arm rest and door handle off and I cant get the panel off. The panel is starting to break right in the center of the door panel at the top, so I stopped prying on it. The panel has the trim at the top and bottom, so I assume I should be able able to flex the center of the panel and it should come out of the trim grooves ??? Does anyone have some pics of the inner door mechanicals available so I can see how everything is suppose to work? I think the panel thats on it is one that someone made to replace the original and it may just be a real tight fit, unless I'm missing something? Any thoughts, ideas or pics would be appreciated> Thanks
