hi all,finally got time to put the hinge pin kits in on my 74 2dr (copperhead)was really easy,opened door,tied wire to detent spring,put jack under end of door,raised it a little,pulled e type clips off hinge pins,knocked up bottom pin n pulled it out,jacked door up a little more pried out spring (no prob) knocked out upper pin,pulled door off,tapped out bushes, put in new bushes,put door back on jack and pushed in ,installed new pins and e clips(top pin first)took the detent spring and sqeezed it in vise and wrapped piece of wire tight around it,put it on detent lever and cut the wire,all is now well with both doors,also replaced door seal with sofseal replacements,very nice!! now i can hear radio lol,ps pin kits and door seals bought on ebay.anyway thought i would share with you all.
:nascar: :chev: :beer: go jj 48
