I'm having issues with leaks. At first I thought it was the weatherstripping so I replaced it with Soffseal weatherstrip. It didn't leak for a few days then I go out and my floor is soaked. I can see one spot that is leaking. When you directly spray water at the top of the door it comes in.
Now, I'm thinking that the door may be sagging. There's obviously a gap between the door and the frame at the top. My question is would a door hinge repair kit work with this or not. I'm not sure if it needs new hinges or just the bushings, pins and springs. Any suggestions or advice?
