if so can you punch in some numbers for me to see what kind of power I can expect to make??:D please
454ci
large oval port heads
7.8:1 compression
edelbrock performer intake
the cam has a 560 lift 280 duration 231 @50 108 lobe center
I will be running a 850cfm Q-jet and stock exhaust manifolds
I used a cam that came with the program, your specs wont be too far off. I think the valve sizes might be off a little too, I just used what the program had.
click on the image, then click the white X in the bottom left coner to expand to actual size and you can see the specs I input in the program
I changed to large tube headers and mufflers and it made 388 hp / BUT 485 ft lbs torque at 3000 RPMS!!. Thats why I suggested polishing the exhaust ports
