Question for all of you guys............
Just got finished tuning my Nova. (350/350, HEI-GM)
Setting the timing, I unplugged the vacuum line at the distributor and clamped it. Then I set timing to 11 degrees BTC. Plugged the vacuum line in and no change on the reading (still 11 deg). The vacuum from the dizzy is connected to the timed port on the passenger side of my edelbrock 1406 carb.
Out of curiosity, I moved it to the full vacuum port on the drivers side of the carb where I currently have the modulator connected from the trans.
When I switched them........... the car's idle jumped up and I could not read the timing mark down on the crank anymore. The vacuum advace really kicked in on the full port. On the timed port = no change.
Which way is normal? I know this has been covered and I've searched but I didn't find out if the idle, or timing, jumps up after reconnecting the dizzy to vacuum.
Just going over my last few checks........ Tomorrow night is my first trip to the strip. And I don't mean strip club! haha
