Hi all,
Is there any way to put disc brakes on a 13" wheel. I have a 63 wagon and would like to get better quality stopping power. I am keeping the 6 cylinder. In the past the drums fade hard on hills and it has gotten a little dicey at times. I have looked around and all bolt on kits seem to be for 14" wheel. I'm new to this so I apologize if this thread has been covered.
NNN
Smallest rotor I see is an 11" rotor and by the time you stack a caliper on it you need over 13" of clearance or the rim rubs the caliper. I can't find one, but you would need a kit with a 10" rotor at the largest and I think that would be a tight fit. After that we have to think about how much cooling will the rotor will actually see sitting in that rim with a backing plate.
Not sure about fitment on your spindle but the 76 Mustang II rotor is a 4 lug 4.25 bolt circle and is 9.3" in diameter. Would fit under a 13" wheel if the wheel will clear the caliper.
Specs
# of Bolts: 4
Bolt Circle Diameter: 4.25 in.
Brake Rotor Diameter: 9.3 in.
Brake Rotor Discard Thickness: .81 in.
Brake Rotor Thickness New: .88 in.
Brake Rotor Type: Disc Brake Rotor And Hub
Height: 3.91 in.
Another option is to go with a larger wheel like these from Summit Racing.
4 lug 14" wheel
