Can anyone tell me what the angle should be from the center line of the ball joints in relation to the spindle. My stock 66 drum arms check apx 6 1/2 deg inward at the top my new a/m spindles are close to 9 deg. What problems is this going to cause with setup ?:confused:
With the spindle at 0 deg flat to the earth a shaft thru the upper an lower ball joint hole the shaft is 6 1/2 deg from vert for drum 9 deg disc.spindles have same size holes top and bottom
Jeff
Jeff
This is called king pin inclination. It should be the same as your stock spindles. Who's spindles did you purchase?
Discussion Starter · #6 ·
Rechecking using both drum spindles I see 7 deg with drum and 9 deg with disc. I'll put it together and deal with it if needed . I read of so many steering problems. I'm just trying avoid them with the tires on the ground. Thanks for replies SNS is great been watching and learning . I like the Church rack much nicer mounting than others i saw a year ago.
Thanks again Jeff
