First off I payed a reputable truck shop that also specializes in diff set-ups along time ago to put in my auburn and 3;73s. All the ring gear bolts are loose and some are backed out a good ways. Also the pattern looks horrible. the loose ring maybe to blame for that.
Well here is my question.
I have the caps marked and off. Axles and clips off and out. But how do you get the diff to pop out.??
I remembered an old tip of putting a wrench on a ring bolt and turning the yolk but that didnt work. I tryed pry bars. I cant get it.
Tomorrow If I cant get it out Im going to take the pinion nut off and pound it out that way. Im not saving the carrier or gears so this thing can hit the ground for all I care. As long As I can keep the shims in order.
