Hi: is there a difference between the 2 and 4 door rear section of the chassis? I have a 4 door and I am thinking about TCI 4 link rear end. I called them and they couldn't say if the rear section of 2 and 4 door chassis are the same or not.
1974 Nova, 1977 Nova
The entire chassis, suspension, subframe, and floor pan (basically the whole bottom part of the car) is the same for both 2 & 4-door. So you should be good to go with the TCI 4 link.
Just what Ray McAvoy says -----------
and, go LOOK HERE :
in the Originality Section : (top area) -- Sticky : Web Link Libary
go down to .. Transmission Parts and Assemblies
Look at the bottom of that list -- for : Ray's Chevy Restoration Site
Very Good INFO ............... and , enjoy .
Thank You , Mr. Ray McAvoy
(alot of very good info located there, by the way) .
I have a 66 4 door and recently completed installing the TCI 4 link kit. Fit perfectly and looks great. I haven’t driven it yet since I’m still doing the motor rebuild /install. I didn’t do a mini tub kit and after research I had the rear built a little longer than the TCI instructions state. With their dimensions on a stock wheel tub you can use a 8.5 inch wide wheel with 4inch backspacing. With those dimensions I couldn’t find any rims that met those specs unless I went with custom wheels. That gets pretty expensive and I wanted to spend my money on other upgrades like the front suspension and motor. I made my rear 55.5 inches as opposed to 54.5 like they recommend. With that I was able to use a an 8 inch wide rim with the standard 4.5 backspacing and it fit perfectly. I’m running a 255/45/17 with plenty of clearance. If you’re going with a mini tub then that obviously changes everything.
