1 - 2 of 2 Posts
I need to know if I covered up a drain hole(s) with seam sealer. On my 62, I had just finished filling some joints in the floorpan and I had just a little left in the tube so I started looking around for someplace to use it. I filled a place where I could see the garage floor. It was under the kick panel, where the channel covered by the sill plate ends, right under where the antenna is mounted. I then also put some at the other end of the channel, where it meets the wheel well. Then I did the other side. You know, I just didn't want any seam sealer to go to waste. Anyway, now I'm wondering if I screwed up and should grind it all out before I put down the sound deadener and carpet. Any thoughts, besides I should watch where I point that caulking gun?
Yep! Thats how the water that enters the cowl gets out! Make sure to open it back up all the way to let dirt and debeis out!!
1 - 2 of 2 Posts
