1 - 1 of 1 Posts
For the street!
434cu 10.7 compression
Dart DHP Block
4.155 bore 4inch stroke
Manley 4340 forged crank
Icon dish pistons
6icnh h-bean Eagle rods
Roller cam (this one gets a hydraulic roller) CCH7 Small base.
Single plan Hurricane intake
DHP heads 2.05 int 1.60 ext
ARP hardware
Melling
Fel Pro
Perfect Circle rings
Manley swedged .080 push rods
Roller rockers 7/16 studs
Cam Only Part #: CCH7
Dur Int-Exh: 280/285
Dur @ .050 Int-Exh: 240/245
Lift 1.5 - 1.5 Int/Exh: 570/585
Lobe Center: 110
Valve Lash: HYD
RPM Range: 2700-6700
Description: Intended for hot street/strip applications. 3000+stall or manual must.
1 - 1 of 1 Posts
